djwarder Posted October 8, 2013 Share Posted October 8, 2013 Anyone attempted to write a shader for milk at all in Houdini? I'm assuming I'd start with using a lot of SSS & forward scattering, but not sure where to go from there. Anyone able to advise at all please? Quote Link to comment Share on other sites More sharing options...
abvfx Posted October 8, 2013 Share Posted October 8, 2013 I would look at the PhysicalSSS vop, if you switch it into Physical mode as opposed to Artist. You get access to all the absorption and scattering coefficients which are used in the presets for the VOP. There is one for Milk. I would suggest that would be a good start, but i wouldnt know where to begin if you are writing in vex (cant even find it in the documentation) Quote Link to comment Share on other sites More sharing options...
djwarder Posted October 8, 2013 Author Share Posted October 8, 2013 Aha great, didn't even see those presets! Thanks, will take a look ... Quote Link to comment Share on other sites More sharing options...
roughsporty Posted November 6, 2013 Share Posted November 6, 2013 hm, it seems that the PhysicalSSS has more functionality than the SSS section of the surface model. If I use a Mantra Surface Node how can I easily implement the PhysicalSSS vop? I'm not a shader guy and wouldn't create a shader from scratch. Quote Link to comment Share on other sites More sharing options...
tmdag Posted November 6, 2013 Share Posted November 6, 2013 (edited) default surface shader preset has physical SSS inside. H12 sets it to "Artistic" mode by default with pointcloud, H13 sets it to raytraced by default Edited November 6, 2013 by tmdag Quote Link to comment Share on other sites More sharing options...
roughsporty Posted November 7, 2013 Share Posted November 7, 2013 But do I have access to the presets of the physicalSSS vop in the default surface shader? Quote Link to comment Share on other sites More sharing options...
dpap Posted January 24, 2014 Share Posted January 24, 2014 (edited) No no no !no dear side fx ! this is shouldn't be called "Artist" mode because it simply is not artist friendly. you dont put an option like that so deeeeep inside! you have to be an artist of the art of Guessing in order to find it... The presets of the Surface shader should simply give the ability to choose: Milk and boom ! Milk! Why cant I see the straw? Can someone help out on how to make a milk shader ? Milk Shader 3.hip Edited January 24, 2014 by dpap Quote Link to comment Share on other sites More sharing options...
mangi Posted January 24, 2014 Share Posted January 24, 2014 Opacity scale ? Quote Link to comment Share on other sites More sharing options...
dpap Posted January 24, 2014 Share Posted January 24, 2014 Thanks Mangi! It does fix it! The bad thing is that I would expect to control it from something like the "Attenuation" parameter somehow. So that it is less opaque neather intersection and more towards the back. Tweacking the opactiy scale kinda makes it more transparent but in a uniform way... Quote Link to comment Share on other sites More sharing options...
LouisXIV Posted January 25, 2014 Share Posted January 25, 2014 (edited) From wich source does sesi have this preset values? Is there somewhere a list in the internet with diffrent materials sss properties?Trial and error?update: i found the paperhttp://graphics.ucsd.edu/~henrik/papers/bssrdf/bssrdf.pdf Edited January 28, 2014 by LouisXIV Quote Link to comment Share on other sites More sharing options...
