Peony Posted May 19, 2004 Share Posted May 19, 2004 Hi everyone! Trying to create ripples on a grid using curve clay + series of scaled profiles/curves on surface. Only problem is that the curveclay affects all of the profiles equally + i would like the effect to die off the larger the profile is (just like ripples)... any suggestions? (other than having to use a seperate curveclay for each profile...) Figured this was more of a modelling question than effects.... as doesn't really involve particles.... Quote Link to comment Share on other sites More sharing options...
DaJuice Posted May 19, 2004 Share Posted May 19, 2004 I'm not sure what you're ultimately going for, but why not use the VEX Ripple SOP? Quote Link to comment Share on other sites More sharing options...
Peony Posted May 20, 2004 Author Share Posted May 20, 2004 I need to be able to control the shape of the ripples using a profile, so i don't think i can use this... Quote Link to comment Share on other sites More sharing options...
Jason Posted May 21, 2004 Share Posted May 21, 2004 Try and use the Wire Deformer instead of the CurveClay? or the LatticeSOP in points mode? Quote Link to comment Share on other sites More sharing options...
exel Posted May 21, 2004 Share Posted May 21, 2004 Hi kukkie-- Here's a quick example of animated ripples using curveclay -- there's a few expressions and channel references in there, but it was just to make the animated series of profile curves... Hope this helps! curveclay_ripple.hip.tgz Quote Link to comment Share on other sites More sharing options...
michael Posted May 21, 2004 Share Posted May 21, 2004 there was a 3D Buzz VTM included on a 3D World cover disk a few months back that had a VOPs tutorial that did rain drops/ripples... Quote Link to comment Share on other sites More sharing options...
Peony Posted May 24, 2004 Author Share Posted May 24, 2004 Hi guys! thanks for all the suggestions, haven't had a chance to look at the file yet but will do. Have tried to go down the wire deformer route but didn't think it was what i want as it's just deforming across a surface in u. However it is capturing the areas i want to displace so i've controlled the displacement by the colour of the capture regions....don't think it's going to be useful for ripples... may need to resort to particles after all (!) but produced an interesting effect... kel.hip.gz Quote Link to comment Share on other sites More sharing options...
Peony Posted May 25, 2004 Author Share Posted May 25, 2004 sorry posted wrong file... hopefully this is the right one! ripple_idea.hip.gz Quote Link to comment Share on other sites More sharing options...
