Follyx Posted October 13, 2013 Share Posted October 13, 2013 (edited) Hi, is there a clear thread for using different kind of meshes, i.e. primitive, polygon, nurbs, mesh etc, in specific/different situations? Thanks in advance Edited October 13, 2013 by Follyx Quote Link to comment Share on other sites More sharing options...
sanostol Posted October 13, 2013 Share Posted October 13, 2013 nurbs and mesh are parametric, they are clearly defined, for example You can carve a nurbs/mesh, but You If You carve a polygonobject every polygon is carved individually. Nurbes and meshes have a uvspace for free, it is not stored on the geometry but if You need it You can get it, even if the geometry is heavily deformed. that does not work on polygons Quote Link to comment Share on other sites More sharing options...
Follyx Posted October 13, 2013 Author Share Posted October 13, 2013 I see, the same approach as in other 3D packages as well. Thank you Quote Link to comment Share on other sites More sharing options...
