sly Posted October 22, 2013 Share Posted October 22, 2013 (edited) Hi, i would like to know if there is a way to loop through points via an attribute value , like the ForEach node does when it s setup on 'each attribute value' . i already know how to make simple loops , but i m stucked in the way to do that via an attrbute value stored in the points. if someone has some ideas , please share thanks. Sylvain. Edited October 22, 2013 by sly Quote Link to comment Share on other sites More sharing options...
moomarkus Posted October 22, 2013 Share Posted October 22, 2013 (edited) ## I'm kinda new to this as well. ## Is there a better way? import hou h=hou.node("/obj/torus_object1/torus1") g=h.geometry() p=g.points() # get list of points geo # pre-get attributes if you wanna find out what's available? # a_pt = p[0] pt_geo = a_pt.geometry() l_attrs = pt_geo.pointAttribs() print "attribues:",l_attrs #### now go through points for whatever attrib value.. ## point position in this simple case. print "size p:",len(p) for pt in p: print i i +=1 # For now, just print attribute "P" print pt.attribValue("P") Edited October 22, 2013 by moomarkus Quote Link to comment Share on other sites More sharing options...
petz Posted October 22, 2013 Share Posted October 22, 2013 you could use a dictionary for that. petz Quote Link to comment Share on other sites More sharing options...
sly Posted October 22, 2013 Author Share Posted October 22, 2013 (edited) so i create a dictionary this way : pts = geo.points() dico = {} for pt in pts: ptNum = pt.number() attrValue = pt.attribValue("class") dico[ptNum] = attrValue is this the correct way ?, i m very noob in python. now i have to find how to use this. Edited October 22, 2013 by sly Quote Link to comment Share on other sites More sharing options...
petz Posted October 22, 2013 Share Posted October 22, 2013 example-file is attached! hth. petz for_val.hipnc 2 1 Quote Link to comment Share on other sites More sharing options...
sly Posted October 22, 2013 Author Share Posted October 22, 2013 thank you a lot for the example petz , very helpfull ! Quote Link to comment Share on other sites More sharing options...
graham Posted October 23, 2013 Share Posted October 23, 2013 I threw this together real quick in an attempt to make something that would try and handle things as efficiently as possible. As it requires numpy and collections so it might not work on all platforms unless those modules are available. It also doesn't support string attributes. This function returns a defaultdict object whose keys are unique attribute values and whose indices are any entity number(s) whose values correspond to the key. It supports points or primitives of any size. from collections import defaultdict import numpy def getPartitionedIndices(attribute): attribType = attribute.type() dataType = attribute.dataType() name = attribute.name() size = attribute.size() # Can't handle string attributes. if dataType == hou.attribData.String: raise hou.OperationFailed("Attribute cannot be a string attribute.") if attribType == hou.attribType.Point: values = numpy.fromstring(attribute.geometry().pointFloatAttribValuesAsString(name), dtype=numpy.float32) elif attribType == hou.attribType.Primitive: values = numpy.fromstring(attribute.geometry().primFloatAttribValuesAsString(name), dtype=numpy.float32) else: raise hou.OperationFailed("Invalid attribute type for {0}. Must be point or primitive.".format(name)) # Convert to integers if necessary. if dataType == hou.attribData.Int: values = values.astype(numpy.int) ddl = defaultdict(list) # Handle attributes whose size is > 1. if size > 1: # If the size is not 1 we need to reshape the flat array to group components together. values = numpy.reshape(values, (float(len(values)) / size, size)) for idx, val in enumerate(values): # Need to convert away the numpy-ness and create at tuple which is hashable. ddl[tuple(val.tolist())].append(idx) else: for idx, val in enumerate(values): ddl[val].append(idx) return ddl 1 Quote Link to comment Share on other sites More sharing options...
