turbosheep Posted November 6, 2013 Share Posted November 6, 2013 Posted: Wed Nov 06, 2013 3:43 am GMT Post subject: Can't select digital asset? So, I finally finished making my first digital asset. Now I'm trying to select the asset from the TAB menu, but when I select it, the TAB menu simply disappears and the asset does not appear as a node. There is no error message either. I click it, and nothing. There are no errors anywhere as far as I can tell. I tried changing the asset's name (adding 'NEW'), didn't help either. I'm a complete newbie at this, so any help would be appreciated. For clarity's sake, when I click THIS: http://puu.sh/5aeTR.jpg Nothing happens. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
tmdag Posted November 6, 2013 Share Posted November 6, 2013 I know that there is a bug in Houdini that haven't been fixed for quite a long time that sometimes nodes do not appear in network editor when you try to create new ones. Creating new network editor panel helps (or restarting Houdini). But that is regarding ALL node types. maybe if you send scene file with otl we can try to recreate this problem. There is no reason why node wouldn't appear after creation (unless it is created specially with instruction to not to appear) Quote Link to comment Share on other sites More sharing options...
turbosheep Posted November 7, 2013 Author Share Posted November 7, 2013 I uploaded the .hipnc file with the asset in it and an OTL file. Hopefully this is enough for someone to see what's up? Thanks. You_Car_Assignment_DONE.hipnc OPcustom.otl Quote Link to comment Share on other sites More sharing options...
acey195 Posted November 7, 2013 Share Posted November 7, 2013 I see your problem, but also do not know for sure why it does not create the actual node. I saw some orange highlights on some of the parameter references, those are things you probably don't want. Additionally I see a lot of non-procedural nodes: poly split nodes and non-procedural groups. I don't know how well OTL's deal with these things, you could try replacing all the polysplits with the new polycut node from H13 and using group nodes to create proper groups instead of selecting them from the viewport. Also, I did something similar a couple of years ago : 1 Quote Link to comment Share on other sites More sharing options...
dave_o Posted November 7, 2018 Share Posted November 7, 2018 Old thread, but I just encountered this problem. I was duplicating an hda, and I encountered behaviour like the above. On 11/6/2013 at 8:51 AM, turbosheep said: Now I'm trying to select the asset from the TAB menu, but when I select it, the TAB menu simply disappears and the asset does not appear as a node. There is no error message either. I click it, and nothing. There are no errors anywhere as far as I can tell. I tried changing the asset's name (adding 'NEW'), didn't help either. I'm a complete newbie at this, so any help would be appreciated. Somehow the contents of the Tools/Script area was deleted. Entering the default script seemed to fix it: import soptoolutils soptoolutils.genericTool(kwargs, '$HDA_NAME') 1 Quote Link to comment Share on other sites More sharing options...
Howitzer99 Posted June 6, 2019 Share Posted June 6, 2019 Looks like my HDA was also missing the Tools/Scripts, so adding back the objecttoolutils worked. Thanks for sharing! 1 Quote Link to comment Share on other sites More sharing options...
