White Water bubbles to foam flickering
daverand
Separating bubbles from foam to treat them differently in the white water tool. Bubbles turn into foam which is desired yet if not treated the same, same shader, same geometry...there's an obvious flicker as the points move from bubbles to foam and back again... any tips?
Edited by daverand
