Hollow Object Fracturing
amination
since Break SOP is cookie based anyway, the only thing you needed was to set Operation to B minus A on your cookie from first post
since by setting it explicitly to Inside A and Outside B you ended up with inside part with wrong facing normals so they didn't make solid piece together
