magneto Posted December 1, 2013 Share Posted December 1, 2013 Hi, I couldn't find more info about it except the help card. But is pcopenlod a lightweight version of pcopen? For example if you don't want distance, or point numbers, but only want to know the point count, etc, can you use it? Thanks Quote Link to comment Share on other sites More sharing options...
sebkaine Posted December 2, 2013 Share Posted December 2, 2013 (edited) I think from what i have undertsand (and chance are that i am wrong ) That pcopenlod = pcopen + the option to manage Level Of Definition. So i guess is that the idea is to optimise your access to a point clouds Basically you define a condition for exemple my Level Of Definition will be base one the distance to a certain point . So If you want to access 1.000.000.000 points pcopenlod will be far more efficient than pcopen cause basically if you are in the distance define by your initial LOD condition fox ex 100m all the points will be access, But then when you will reach a certain distance , point will be sorted in a K-tree structure to optimise access and thus instead of acessing 1.000.000.000 points you will only access 500.000. To access the other one the condition that define your LOD must be match ... I don't see any reason why they would block all the other command like pcnumfound but the doc doesn't mention it ! i think it's something like that , but i have never try it in the realworld , but it looks to be a very powerful weapon for pop stuff ! anyway i'm afraid i doesn't help you much than the doc Cheers E Edited December 2, 2013 by sebkaine 1 Quote Link to comment Share on other sites More sharing options...
magneto Posted December 16, 2013 Author Share Posted December 16, 2013 Thanks sebkaine. Sorry I had to put this on hold but in my tests it was slower. I am not sure if I used the right settings to make it mimic the standard pcloud open but with limited number of points and threshold. I will report back when I do so, but anyone is free to chime in with their findings as well Quote Link to comment Share on other sites More sharing options...
