sop attrs in dops
jasonj3d
on Dop Import SOP add up to Vector Attributes To Transform parm list
also make sure up has qualifier set to vector otherwise it will not get transformed, you can set qualifier in Attribute Create SOP or Add Attribute VOP, just creating it in wrangle sops through @ is not enough
I checked it now, you values are matching for sop level "up", dopnet "up".
dop import "up" values are updating every frame because "up" is added in "vector attribute to transform" as anim suggested.
If you check values in all levels at first frame all are same.
dop import "up" is updating after the simulation based on the geometry transformation ( correct me if I am wrong), its not related to dopnet.
If you want to update these values in dops, you have to modify existing up value using modify data DOP.
Edited by kare
