magneto Posted December 15, 2013 Share Posted December 15, 2013 Hi, I am trying to import the velocity field from dops into sops, but when I do so, the resolution doesn't match. It doesn't even match between the components. All I do is this: 1. Create a sphere. 2. Use Billowy Smoke from the Shelf. 3. Inside import subnet, on the import_pyro_visualization node, set Geometry Data Path to vel. 4. Go to frame 14. 5. And compare the resolution of both volumes using the MMB. dopnet shows [26, 29, 28] import_pyro_visualization node shows this: How can I make sure that I am getting the exact volume from the dopnet? Thanks Quote Link to comment Share on other sites More sharing options...
anim Posted December 15, 2013 Share Posted December 15, 2013 because velocity volumes are Face sampled in pyro by default to make them exact as density just go to your smoke object/Initial Data/Velocity Sampling and set it to Center 1 Quote Link to comment Share on other sites More sharing options...
magneto Posted December 15, 2013 Author Share Posted December 15, 2013 Thanks anim, I had no idea that would be the reason. You are a lifesaver Quote Link to comment Share on other sites More sharing options...
