jwhit6142004 Posted December 17, 2013 Share Posted December 17, 2013 (edited) So im having a little trouble figuring out why what happens in my render window is different than the viewport. I wanted purple smoke but when it renders it is white. Here are the two pictures to compare and also the file included. Thank you in advance for any feedback 12_16_13_HIGHRES_ShockwaveV1.hipnc Edited December 17, 2013 by jwhit6142004 Quote Link to comment Share on other sites More sharing options...
Skybar Posted December 17, 2013 Share Posted December 17, 2013 It's because you have only changed the visualisation, and you havent applied a shader. Do that and change the color in the shader instead, then it will work when rendering. Quote Link to comment Share on other sites More sharing options...
jwhit6142004 Posted December 17, 2013 Author Share Posted December 17, 2013 what shader would you suggest just for smoke? Quote Link to comment Share on other sites More sharing options...
Skybar Posted December 17, 2013 Share Posted December 17, 2013 The really simple one would be Billowy Smoke, might be enough for this. I really like the Pyro shader though, it got tons of control. Quote Link to comment Share on other sites More sharing options...
