Wolfwood Posted July 28, 2014 Share Posted July 28, 2014 (edited) Blinn with a shiny value mapped to a equivalent roughness value. GGX model, notice you can still see the terminators. This is a straight distribution, not a full microfacet model. GGX microfacet model, includes Fresnel, Geometric masking term and "N dot L" Edited July 29, 2014 by Wolfwood Quote Link to comment Share on other sites More sharing options...
Serg Posted July 29, 2014 Share Posted July 29, 2014 That looks great, you tease! I hope sideFx are looking into this. I can get reflections like this in traditional workflow (just as an exercise before the bsdf headache) with artist control over the `tails` (For loop, disturbing N with gauss rand noise, with pow to tweak the peak, plugged into phys spec set to cone and zero angle, etc) works fine for indirect reflections but its obviously horribly noisy for tracing direct area lights. On one hand I'm kind of hoping to be forced to make my own ggx type bsdf, on the other I have a ton of other important stuff to do! Quote Link to comment Share on other sites More sharing options...
Wolfwood Posted July 29, 2014 Share Posted July 29, 2014 That looks great, you tease! I hope sideFx are looking into this. I can get reflections like this in traditional workflow (just as an exercise before the bsdf headache) with artist control over the `tails` (For loop, disturbing N with gauss rand noise, with pow to tweak the peak, plugged into phys spec set to cone and zero angle, etc) works fine for indirect reflections but its obviously horribly noisy for tracing direct area lights. On one hand I'm kind of hoping to be forced to make my own ggx type bsdf, on the other I have a ton of other important stuff to do! The plan is to post the ggx, disney bsdf implementation plus a big microfacet swiss army knife similar to the compare.brdf in BRDF in the next day or so once I finish up writing the help. 3 Quote Link to comment Share on other sites More sharing options...
Serg Posted July 29, 2014 Share Posted July 29, 2014 Wow! That's just amazing, I hope you can handle all the free beer! Q re the inclusion of Fresnel within the bsdf. Does this lead to more plausible results? I've read in a couple of places that it is separable, as in you can just mult the bsdf with Fresnel, which is what my ubershader and sesi surface model does. Its probably my inability to understand these papers in depth, but I have always thought it was strange for this to be accurate with rough reflections. I would have thought that as the ray deviates from a perfect mirror a different Fresnel result would be needed per ray coz the microfacet angle is different than the geometric. Am I talking crapola? Quote Link to comment Share on other sites More sharing options...
Wolfwood Posted July 30, 2014 Share Posted July 30, 2014 (edited) I would have thought that as the ray deviates from a perfect mirror a different Fresnel result would be needed per ray coz the microfacet angle is different than the geometric. This. The Fresnel component is taken with respect to microfacet's normal (the half vector between the light vector and eye vector) not the surface normal. Because you need the sample direction of the light to compute the half angle, which is only available inside the pathtracing engine, the ideal place to do this is within the bsdf (or rewrite the pbr engine). For mirror-like surfaces this isn't a problem but like you said, the rougher the surface the more this contribution makes a difference. Which one is right? Which ever the client thinks looks better. As a side note- In all my testing I've been using PBRT as a "ground truth" because its has had a lot of different rendering experts studying it closely over the years and its very well documented. So when doing these Mantra BSDFs, like the GGX microfacet, I'll test them in PBRT to make sure that I get similar images. Its somewhat impressive that given the same camera, geometry, lights positions along with the same implementations of BSDF model how incredibly close the resulting two images will be. PBRT & Mantra Edited July 30, 2014 by Wolfwood Quote Link to comment Share on other sites More sharing options...
Serg Posted July 31, 2014 Share Posted July 31, 2014 Thats great, the effect is what I expected to happen Goes some way to explain why I failed miserably to shade very rough surfaces (like brick/concrete) whilst trying to follow the physical correct rule of `everything is 100% reflective at glancing angle`. This looks like it would surely help to stay within `real` parameters, but actually get `real` looking results too... Porosity is another thing that shading models ignore, which can account for over bright rough reflections. There's something about that on one of my fave blog, march 17th post: http://www.filmicworlds.com/ Quote Link to comment Share on other sites More sharing options...
Wolfwood Posted July 31, 2014 Share Posted July 31, 2014 (edited) Porosity is another thing that shading models ignore, which can account for over bright rough reflections. There's something about that on one of my fave blog, march 17th post: http://www.filmicworlds.com/ Wow.... so many gems. Must....read...it..all. Thanks. Ps- I'll post everything I have tonight just to get some more eyes on it. Though its all being worked on from time to time. (I spent the morning figuring out why a render was going black, turns out a value ended up being raised to the 4th power over the course of execution pushing the small value beyond the happiness to floating point land.) Edited July 31, 2014 by Wolfwood Quote Link to comment Share on other sites More sharing options...
eetu Posted July 31, 2014 Share Posted July 31, 2014 Awesome, based on the screenshot it's exactly what it should be! The only ambiguity in GGX I've run into is how the smoothness value is mapped - everybody seems to have their own little variation on it. (At least in the realtime world.) Are you using the Disney one? (GGX roughness = Disney roughness ^2) The parameter ranges can be a bit non-intuitive at first, so a value chart would be great to have in the help page - but you probably are already on it Quote Link to comment Share on other sites More sharing options...
Wolfwood Posted July 31, 2014 Share Posted July 31, 2014 (edited) I use the disney roughness^2. It maps into a somewhat nice range. In the end the cvex models take an alpha parameter. The front-end (the VOP) does the remapping. And on the help pages I'm including links to as many of the references as possible. Ultimately this is such a huge topic it makes doing the help page a bit daunting, so I've opted for here is the parameters and a brief description of what they do and then tons of links. Edited July 31, 2014 by Wolfwood Quote Link to comment Share on other sites More sharing options...
eetu Posted August 1, 2014 Share Posted August 1, 2014 You probably have much of the same, but I'll just dump my bookmark list here anyway. These are a bit game oriented, but it's all the same, really, these days http://graphicrants.blogspot.com/2013/08/specular-brdf-reference.html http://simonstechblog.blogspot.com/2011/12/microfacet-brdf.html http://disney-animation.s3.amazonaws.com/library/s2012_pbs_disney_brdf_notes_v2.pdf http://blog.selfshadow.com/publications/s2013-shading-course/rad/s2013_pbs_rad_notes.pdf http://blog.selfshadow.com/publications/s2013-shading-course/karis/s2013_pbs_epic_notes_v2.pdf https://www.cs.cornell.edu/~srm/publications/EGSR07-btdf.pdf http://seblagarde.wordpress.com/2011/08/17/hello-world/ http://seblagarde.wordpress.com/2011/08/17/feeding-a-physical-based-lighting-mode/ https://dl.dropboxusercontent.com/u/55891920/papers/mm_brdf.pdf http://interplayoflight.wordpress.com/2013/12/30/readings-on-physically-based-rendering/ http://www.thetenthplanet.de/archives/255 http://www.chrisevans3d.com/pub_blog/moving-physically-based-shading/ http://renderwonk.com/publications/s2010-shading-course/hoffman/s2010_physically_based_shading_hoffman_a_notes.pdf http://renderwonk.com/publications/s2010-shading-course/hoffman/s2010_physically_based_shading_hoffman_b_notes.pdf (and pretty much all the rest of the siggraph shading course notes) 1 Quote Link to comment Share on other sites More sharing options...
Wolfwood Posted August 1, 2014 Share Posted August 1, 2014 You probably have much of the same, but I'll just dump my bookmark list here anyway. These are a bit game oriented, but it's all the same, really, these days Indeed, nice list! This one is quite nice from this year, they talk about supporting an anisotropic geometric term. Its on my todo list. http://hal.archives-ouvertes.fr/docs/00/94/24/52/PDF/RR-8468.pdf Quote Link to comment Share on other sites More sharing options...
Wolfwood Posted August 7, 2014 Share Posted August 7, 2014 (edited) Splat Edited August 7, 2014 by Wolfwood Quote Link to comment Share on other sites More sharing options...
