Lukich Posted June 18, 2004 Share Posted June 18, 2004 this problem have persisted through the last several versions of houdidni. you render something in mplay and if you kill mplay, the houdini doesn't come back up. the only way to fix it is to go to task manager and kill mplay process. and with 6.5 it doesn't always do it, for some reason. Is it my nardware configuration or a common problem? Quote Link to comment Share on other sites More sharing options...
michael Posted June 21, 2004 Share Posted June 21, 2004 I've had the problem of doing a flipbook > the images start to load in and I try to close mplay...everything just locks up untill I kill mplay... Quote Link to comment Share on other sites More sharing options...
mark Posted June 21, 2004 Share Posted June 21, 2004 you may be able to kill the mantra process not houdini itself, it has worked for me in the past.. Quote Link to comment Share on other sites More sharing options...
Lukich Posted June 21, 2004 Author Share Posted June 21, 2004 Right, that's what I end up doing. And if it's iPlay, I also have to kill another process called idialog. It works 95% of the time. I actually messed up because I wanted to submit that into the suggestions category hoping that it'll get fixed in the next cuts of Houdini Quote Link to comment Share on other sites More sharing options...
