dpap Posted January 25, 2014 Share Posted January 25, 2014 Why can't I see the color of the cylinder when its inside the cube? refraction.hip Quote Link to comment Share on other sites More sharing options...
mangi Posted January 25, 2014 Share Posted January 25, 2014 Check Tab on snap shot Mangi refractionfix.hipnc 1 Quote Link to comment Share on other sites More sharing options...
dpap Posted January 25, 2014 Author Share Posted January 25, 2014 Thanks Mangi! I guess I had underestimated the specific tab! It does change though the look of the shader by a lot if you enable it while refraction and sss are on . Quote Link to comment Share on other sites More sharing options...
mawi Posted January 25, 2014 Share Posted January 25, 2014 Try the Faux caustic checkbox instead. 1 Quote Link to comment Share on other sites More sharing options...
dpap Posted January 25, 2014 Author Share Posted January 25, 2014 (edited) Awesome!!! Thanks Mawi!!! Edit---------------------------- hmmm ...definitely better with "faux caustics" but you get something like an artifact at the intersection point..Is there a way to get rid of it? refraction 1.hip Edited January 25, 2014 by dpap Quote Link to comment Share on other sites More sharing options...
Green-Man Posted January 26, 2014 Share Posted January 26, 2014 (edited) Looks like you should decrease the bias of the rays. Edited January 26, 2014 by Green-Man 1 Quote Link to comment Share on other sites More sharing options...
dpap Posted January 26, 2014 Author Share Posted January 26, 2014 Thanks Green-Man!!! I don't know if there is a dowside in this but setting the Bias to 0.000001 makes it disappear! Quote Link to comment Share on other sites More sharing options...
Green-Man Posted January 26, 2014 Share Posted January 26, 2014 If you set the global bias to very small value is for example becomes possible for objects to shadow itself. So technically the surface could send a ray in some direction and hit itself in in the origin of the ray. 0.000001m = 10e-6m =1000 nanometres. Nanographics is coming:) Quote Link to comment Share on other sites More sharing options...
