Is there a way to create uniform, evenly sized voronoi pieces in H13?
magneto
That sounds like stippling
http://www.joesfer.com/?p=108
Does that also apply to 3d? I assume that growing on an arbitrary 3d surface might be alot harder than 2d. Not sure if the extension to 3d would be straight forward to implement.
the only way i can think of how you would get perfect equidistant points is to use a circle packing. but if you don´t want any approximation this could become quite challenging on arbitrary 3D meshes if it´s done right...
Circle packing would still require iterations, right? Also isn't circle packing very similar to point cloud and minimum position approach where points repel each other using a radius? I assume the difference is circle packing uses strictly 2d distances on the surface instead of 3d distances?
Remesh SOP > Divide SOP
Remesh SOP creates evenly sized equilateral triangles followed by a Divide SOP and tick on 'compute dual' will give you voronoi cells.
You can take it a step further and get the center pts of those cells to plug into a voronoi fracture
uniformVoronoiCells_v1.hip
no, no, a real circle packing has nothing to do with repelling points. that would be more like a rough approximation. but as i said before, for exact circle packings on 3d surfaces rather heavy math is involved...
Edited by petz
Thanks SpencerL, I tried it by creating points at the center of the voronoi cells but some points still end up inside the surface. I used the Ray SOP's Minimum Position but the points still seem to bunch up at certain places of the surface.
I made a comparison of it with the relaxation method, top and bottom respectively:
Still an interesting approach :)
no, no, a real circle packing have nothing to do with repelling points. that would be more like a rough approximation. but as i said before, for exact circle packings on 3d surfaces rather heavy math is involved...
Thanks petz. Do you know any good papers or examples of it online? When I search, lots of grasshopper links show up.
But the videos I found still seem to show them do this iteratively like this one:
Even if it's math intensive, it wouldn't hold you back :)
well, that is NOT a circle packing!
i guess it is just a spring based model what could easily be done in houdini by using a triangular mesh with pre-assigned restlength and some vex/vops inside a sop-solver. but at the end i don´t think it would be more correct than what christian did in his otl, probably with more iterations.
do a search for kenneth stephenson and you´ll find plenty of scientific papers for circle packings in 2d and some for 3d
oh, actually it does! i tried it once but after all i gave up because it became rather "academic" and i thought it wasn´t worth the work for what i needed it. a good approximation was enough at the end...
Edited by petz
