a question for the fire gods....pyro newb problems
hey guys, i'm new to pyro but starting to get some results.   The image below I used Smokeless fire and I have two questions:
1. why is there so much smoke (since i used Smokeless off the shelf)?   How can i remove it (I understand it's necessary for the sim, but how can I avoid RENDERING it?....or ideally even computing it if possible) ?
2. why is it so.....pixelated / noise looking in the render?  It's not smooth and silky it's all points.  I've messed w/ some of the Mantra settings but no luck..
Any help on either topic greatly appreciated, thanks!
post-11023-0-46650300-1391550634_thumb.j
Can you please post your scene?
Its really hard to tell without.
Thanks,  I didn't actually have all those videos/links....I figured out how to remove the smoke, thanks!
i've read quite a bit on pyro, and done a ton of tutorials on youtube/vimeo....but have not found this exact problem re: noise in the render.
Here is my scene....much thanks; great community!
pyro_test_2_04.hipncFetching info...
Edited by jsunandmax
the noise in the render; try these settings in Mantra; Properties/Sampling/
Pixel Samples 4
Transparent Samples 12.
Noise in volumes should be easy to find forum posts on.
