Tato Posted February 5, 2014 Share Posted February 5, 2014 Hi folks. I'm rendering two object, one is animated and another one is packed object which is driven by DOP-s. I'm adding displacement at render time using "rest" position but the object is sliding through displacement. Any advice? I'll attach hip file here: rest_position.hip Quote Link to comment Share on other sites More sharing options...
Skybar Posted February 5, 2014 Share Posted February 5, 2014 It's because you've left the rest position input on the Rest SOP empty. You connect the deforming/animated geometry to the left, and a static frame of that geometry to the right. I don't now much about Packed Primitives though, so I don't know the workflow there. But if you unpack it, it works. rest_position_dv.hip Quote Link to comment Share on other sites More sharing options...
Tato Posted February 5, 2014 Author Share Posted February 5, 2014 Thank you David Quote Link to comment Share on other sites More sharing options...
