Cache Path Modify
schiho
  • 1 month later...
On Windows, the default value for HOUDINI_TEMP_DIR is taken from the value of TEMP. So if you change TEMP, then HOUDINI_TEMP_DIR will also inherit that value, unless of course, if you also set HOUDINI_TEMP_DIR explicitly. This allows one to have different temp directories for regular Windows and Houdini applications.
