cloudfx Posted February 12, 2014 Share Posted February 12, 2014 Hi guys, I am exporting a geo with point attributes. I am trying to export Cd so that I can read the color attribute in Maya and multiply with diffuse or color in Maya shaders. Any comments would be really appreciated. Thanks, 1 Quote Link to comment Share on other sites More sharing options...
reny Posted February 12, 2014 Share Posted February 12, 2014 remember to use HDF5 format. promote your houdini point attribute to vertex attribute as a backup. And if you are using maya stock alembic plugin, good luck. Quote Link to comment Share on other sites More sharing options...
cloudfx Posted February 12, 2014 Author Share Posted February 12, 2014 Great. I will be using mental ray to render this and would there be an expression to put in for diffuse color parameter (or similar) to have my shader to read vertex/point's Cd attribute from Houdini? Any example would be really helpful. Thank you Quote Link to comment Share on other sites More sharing options...
reny Posted February 12, 2014 Share Posted February 12, 2014 I dont use mr anymore but I think once you can read alembic successfully, vertex color will become a maya color set. You can then do whatever you like in mr with its vertex color node. Check the colormix example come with houdini, and promote Cd into a vertex attribute would do, and cross your finger that maya abcImport works fine, Quote Link to comment Share on other sites More sharing options...
tricecold Posted February 13, 2014 Share Posted February 13, 2014 If you import, with CD attribute by default, Alembic will import but you wont see anything on Viewport however, Maya wires the wrong information to world/mesh, in this case it tries to make a mesh out of CD and it fails, in this case fix the connections from Node editor, I wasnt able to read back the Cd properly, so I am open that suggestion as well. Quote Link to comment Share on other sites More sharing options...
cloudfx Posted February 13, 2014 Author Share Posted February 13, 2014 (edited) I dont use mr anymore but I think once you can read alembic successfully, vertex color will become a maya color set. You can then do whatever you like in mr with its vertex color node. Check the colormix example come with houdini, and promote Cd into a vertex attribute would do, and cross your finger that maya abcImport works fine, Could you tell me more about how to read the vertex color of the geometry into shader? (I am not a maya confortable dude) and also where would I change HDF5? format setting Edited February 13, 2014 by cloudfx Quote Link to comment Share on other sites More sharing options...
cloudfx Posted February 14, 2014 Author Share Posted February 14, 2014 I got this error when I export with HDF5 from H13 to Maya2014. // Error: file: C:/Program Files/Autodesk/Maya2014/scripts/AETemplates/AEnewColor.mel line 42: Attribute facetted:attribpromote4.Cd is not vector-valued. Quote Link to comment Share on other sites More sharing options...
cloudfx Posted February 22, 2014 Author Share Posted February 22, 2014 I got this error when I export with HDF5 from H13 to Maya2014. // Error: file: C:/Program Files/Autodesk/Maya2014/scripts/AETemplates/AEnewColor.mel line 42: Attribute facetted:attribpromote4.Cd is not vector-valued. -rcs / recreateAllColorSets IC3/4fArrayProperties with face varying scope on IPolyMesh and ISubD are treated as color sets even if they weren't written out of Maya. -rcs options seems to work. Quote Link to comment Share on other sites More sharing options...
