Alexey Vanzhula Posted February 13, 2014 Share Posted February 13, 2014 (edited) I have 2 HDK questions: 1. how to get primitive\vertex\point\edge under the mouse pointer? 2. how to highlight this component with opengl? I can only get primitive under the pointer with hou.GeometryViewport.queryPrimAtPixel and hou.GeometryViewport.mapFromMouseChop. But i need hdk solutions. There are very low info for this . I see DM_VPortAgent.singlePickObject method, but i dont understand how to work with render hooks Edited February 13, 2014 by Alexey Vanzhula Quote Link to comment Share on other sites More sharing options...
edward Posted February 14, 2014 Share Posted February 14, 2014 Architecturally, you need a custom "state" to do this. For example, the MSS_* files in the HDK samples. Quote Link to comment Share on other sites More sharing options...
Alexey Vanzhula Posted February 14, 2014 Author Share Posted February 14, 2014 Thanx Quote Link to comment Share on other sites More sharing options...
Alexey Vanzhula Posted February 27, 2014 Author Share Posted February 27, 2014 Maybe it is easier method to know what point under the pointer? I need inlinecpp python solution (i cant use compiled hdk plugins in my asset) - so creation of new state can`t help me. It is some closest point methods, but when i have mouse ray intersected with 3d point i need some camera angle to multiply with it for valid world point Quote Link to comment Share on other sites More sharing options...
Alexey Vanzhula Posted March 2, 2014 Author Share Posted March 2, 2014 (edited) I want to compile MSS_CustomBrushState example, but houdini crushed with: "Couldn`t open MSopStates13.0.338/MSS_CustomBrushState.ui for reading ...". Where i have to put this ui file ? Edited March 2, 2014 by Alexey Vanzhula Quote Link to comment Share on other sites More sharing options...
Guest mantragora Posted March 2, 2014 Share Posted March 2, 2014 I want to compile MSS_CustomBrushState example... Put it anywhere in your DSO path. Just create "ui" folder inside and put it there. Example $HOME/HoudiniX.X.XXX/dso/ui Quote Link to comment Share on other sites More sharing options...
Alexey Vanzhula Posted March 2, 2014 Author Share Posted March 2, 2014 I don`t understand. i put file MSS_CustomBrushState.ui to ~/houdini13.0/dso/ui and also to ~/houdini13.0/dso/ui/MSopStates13.0.338 but it doesnt helped Quote Link to comment Share on other sites More sharing options...
Guest mantragora Posted March 2, 2014 Share Posted March 2, 2014 (edited) Actually, check where your HOUDINI_UI_APP_PATH variable points to. I'm not using $HOME at all and my variable doesn't point to it, and i'm not sure is it by default. So run Command Line Tools and then "hconfig -a" and check its paths. Edited March 2, 2014 by mantragora Quote Link to comment Share on other sites More sharing options...
Alexey Vanzhula Posted March 2, 2014 Author Share Posted March 2, 2014 HOUDINI_UI_PATH := '<not defined>' Quote Link to comment Share on other sites More sharing options...
Alexey Vanzhula Posted March 2, 2014 Author Share Posted March 2, 2014 run houdini with HOUDINI_UI_PATH=/home/alexey/houdini13.0/dso/ui/ /opt/hfs/bin/houdinifx get me ERROR: Couldn't open resource file "resources" (No such file or directory) ERROR: Couldn't open "Fuse13.0.338/FUSE_ColorOptions.ui" for reading: No such file or directory Color name 'ListEntry1' is missing from the theme. Color name 'ListEntry2' is missing from the theme. Color name 'TextboxBG' is missing from the theme. ERROR: Couldn't open "SI13.0.338/SI_ColorEditor.ui" for reading: No such file or directory 10248: Fatal error: Segmentation fault (sent by pid 0) Crash log saved to /tmp/crash.alexey_10248_log.txt Quote Link to comment Share on other sites More sharing options...
Alexey Vanzhula Posted March 2, 2014 Author Share Posted March 2, 2014 (edited) also HOUDINI_UI_APP_PATH := '<not defined>' Edited March 2, 2014 by Alexey Vanzhula Quote Link to comment Share on other sites More sharing options...
Guest mantragora Posted March 2, 2014 Share Posted March 2, 2014 (edited) run houdini with HOUDINI_UI_PATH=/home/alexey/houdini13.0/dso/ui/ /opt/hfs/bin/houdinifx WTF? Why there is a space in your path? On linux I think you should use comma (or maybe it was semicolon?) to separate two paths. Edited March 2, 2014 by mantragora Quote Link to comment Share on other sites More sharing options...
Alexey Vanzhula Posted March 2, 2014 Author Share Posted March 2, 2014 No it is /opt/hfs/bin/houdinifx hou exec command with "inline" variable HOUDINI_UI_PATH. Simple bash runtime Quote Link to comment Share on other sites More sharing options...
Alexey Vanzhula Posted March 2, 2014 Author Share Posted March 2, 2014 ok. it is simple hdk example. Where (in HDK help) can i read how to compile correctly this simple example ? Quote Link to comment Share on other sites More sharing options...
Guest mantragora Posted March 2, 2014 Share Posted March 2, 2014 (edited) "Couldn`t open MSopStates13.0.338/MSS_CustomBrushState.ui for reading ...". Are you sure you have your permissions set correctly for this file? There is really not much philosophy there, you just compile it and that's it. If you can compile other examples like SOPs etc. it should work too. http://www.sidefx.com/docs/hdk13.0/hdk_intro_compiling.html Edited March 2, 2014 by mantragora Quote Link to comment Share on other sites More sharing options...
Alexey Vanzhula Posted March 2, 2014 Author Share Posted March 2, 2014 (edited) No i can compile all examples. but not this with ui file. also this ui file is empty Edited March 2, 2014 by Alexey Vanzhula Quote Link to comment Share on other sites More sharing options...
Alexey Vanzhula Posted March 2, 2014 Author Share Posted March 2, 2014 Are you sure you have your permissions set correctly for this file? All read permissions for all users Quote Link to comment Share on other sites More sharing options...
Guest mantragora Posted March 2, 2014 Share Posted March 2, 2014 Once you modified HOUDINI_UI_APP_PATH make sure there is "$HFS/houdini/config/Applications" added to it and then add to it your custom path. Those errors about "Color name 'TextboxBG' is missing from the theme." etc. are because of this. Quote Link to comment Share on other sites More sharing options...
Alexey Vanzhula Posted March 2, 2014 Author Share Posted March 2, 2014 (edited) At now id dont think that it is problem with ui file but it also crash with this log: Crash report from alexey; Houdini FX Version 13.0.338 [linux-x86_64-gcc4.6] Traceback from Sun Mar 2 20:10:43 2014 Caught signal 11 AP_Interface::coreDumpChaser(UTsignalHandlerArg) <libHoudiniUI.so> AP_Interface::si_CrashHandler::chaser(UTsignalHandlerArg) <libHoudiniUI.so> signalCallback(UTsignalHandlerArg) <libHoudiniUT.so> UT_Signal::UT_ComboSignalHandler::operator()(int, siginfo*, void*) const <libHoudiniUT.so> UT_Signal::processSignal(int, siginfo*, void*) <libHoudiniUT.so> killpg <libc.so.6> PI_ResourceManager::getBindingSelectors(OP_Operator*) const <libHoudiniPRM.so> MSS_SingleOpState::findNextParmWithSelector(int) const <libHoudiniAPPS3.so> MSS_SingleOpState::handleSelectorDone(UI_Event*) <libHoudiniAPPS3.so> BM_SingleOpState::generate(BM_SimpleState::BM_EntryType, bool) <libHoudiniAPPS2.so> MSS_SingleOpState::generate(BM_SimpleState::BM_EntryType, bool) <libHoudiniAPPS3.so> BM_OpStateControl::enterState(BM_State*, BM_OpStateEntry) <libHoudiniAPPS2.so> BM_OpStateControl::setCurrentState(char const*, int, BM_OpStateEntry, BM_SceneManager*) <libHoudiniAPPS2.so> HOMF_SceneViewer::setCurrentState(char const*, bool) <libHoudiniAPPS3.so> _wrap_SceneViewer_setCurrentState <_hou.so> PyEval_EvalFrameEx <libpython2.7.so.1.0> PyEval_EvalCodeEx <libpython2.7.so.1.0> PyEval_EvalFrameEx <libpython2.7.so.1.0> PyEval_EvalCodeEx <libpython2.7.so.1.0> PyEval_EvalCode <libpython2.7.so.1.0> PY_CompiledCode::evaluateUsingDicts(PY_Result::Type, void*, void*, PY_Result&) const <libHoudiniUT.so> SHLF_Tool::execute(SHLF_ExecContext const&) <libHoudiniAPPS2.so> OPUI_ToolHandler::handleToolEvent(UI_Event*) <libHoudiniAPPS2.so> UI_Queue::processNextEvent() <libHoudiniUI.so> UI_Queue::drain() <libHoudiniUI.so> UI_Queue::eventLoop() <libHoudiniUI.so> main <libHoudiniUI.so> __libc_start_main <libc.so.6> [0x1bd7] <houdinifx-bin> Edited March 2, 2014 by Alexey Vanzhula Quote Link to comment Share on other sites More sharing options...
Alexey Vanzhula Posted March 2, 2014 Author Share Posted March 2, 2014 (edited) 11003: Fatal error: Segmentation fault (sent by pid 0) Saving application data to /tmp/crash.untitled.alexey_11003.hip Crash log saved to /tmp/crash.untitled.alexey_11003_log.txt Warning: Missing charsets in String to FontSet conversion it is with custom HOUDINI_UI_APP_PATH var. After i seted it error with ui file was gone Edited March 2, 2014 by Alexey Vanzhula Quote Link to comment Share on other sites More sharing options...
