highlight geometry component under the mouse
Sorry, just found some time to catch up on forums. Here's what worked for me on Windows, which should operate the same in Linux.
Make sure to replace XYZ below with your build number!
$ hcustom MSS_CustomBrushState.C SOP_CustomBrush.C
$ mkdir -p ~/houdini13.0/config/Applications/MSopStates13.0.XYZ
$ cp MSS_CustomBrushState.ui ~/houdini13.0/config/Applications/MSopStates13.0.XYZ
Now you create an object, say a Torus, dive inside and then with your mouse in the viewport, do TAB > Custom Brush.
