wateryfield Posted February 14, 2014 Share Posted February 14, 2014 It is some change in light node on H13, i find the new parameter light contributions. I read the help , is it use for switch the on or off of the diffuse,reflect or other pass . i have try to figer it out , but it have no difference, or just i was wrong. Thank you! Quote Link to comment Share on other sites More sharing options...
dickagm Posted March 7, 2014 Share Posted March 7, 2014 For example if you want to turn the light specular emission off, just add reflection component and turn it off. If you want the light to cast only specular then add all other components (diffuse,refract,indirect, etc...) and turn them off and optionally you can add the reflection component and keep it switched on. Hope that's helpful. Quote Link to comment Share on other sites More sharing options...
wateryfield Posted March 7, 2014 Author Share Posted March 7, 2014 For example if you want to turn the light specular emission off, just add reflection component and turn it off. If you want the light to cast only specular then add all other components (diffuse,refract,indirect, etc...) and turn them off and optionally you can add the reflection component and keep it switched on. Hope that's helpful. Thanks! dickagm. It works just like you say. Very convenient. Quote Link to comment Share on other sites More sharing options...
