Getting weird checkerboard artifact
I am trying to render a football with mantra PBR and in specular I am getting weird checkerboard type artifact. I have attached a screenshot..no other object or material is present in scene so its not a reflection.
Please have a look and give me a solution.
Thanks
post-10148-0-40121600-1393737306_thumb.j
Looks like it may be a faceting issue.
Try dropping a facet node at the end of the node network and select the "Post-Compute Normals" option, and see if that makes any difference.
Either that, or perhaps there's double layer geometry intersecting itself?
Hope that helps,
Matt.
  • 3 weeks later...
  • 8 months later...
Thought I'd share this just in case somebody else has the same issue and can't solve it with anti-aliasing settings (or doesn't know how, like me :P ).
I had the same problem with an .obj imported from Maya: when I assigned a material in Houdini it came out checkered.
I just had to put zero in the Specular Anisotropy, in the Reflect/Base/Reflect Lights tab.
Probably not the best solution but hey, it worked for me.
Edited by yalla
