How works Gas Sand Forces
sliver
Hi guys :)
Does anyone know how the GasSandForces DOP works with a flipsolver to convert each particles as grains ?
I haven't read any solution on forums.
The Gas Sand Forces DOP computes the local strain and pressure at each point in the fluid. The fluid is then broken into a series of rigid components whose strain is insufficient to separate the grains of sand. These components velocities are projected to be rigid.
http://www.sidefx.com/docs/houdini13.0/nodes/dop/gassandforces
I'm not sure about what I have write there, is it correct ? :
Velocity Field :     vel
Surface :             surface
Pressure :           pressure
Strain :                strain
To complete, it seems that the Gas Sand Forces need a pressure field and the Gas Project Non Divergent could be used in this case to compute pressure. (but I'm stuck about this 2 nodes)
Thank you in advance if you can help me.
My file if you want to explore it.
GasSandForces_RnD_001.hip
Edited by sliver
Hi Skybar, may be, I hope not, it's not define in the help. I think to work correctly I need to use the Gas Project Non Divergent  to compute the pressure in the Gas Sand Forces but I don't know how these microsolver works.
