Doum Posted March 6, 2014 Share Posted March 6, 2014 Hey all, I'm playing with Pop to create a confettis setup. I had some difficulty to figure out how to make particles align to the collider object when they hit. I did some test with a vop pop and playing with orient attribute but I had problem mixing 2 orientation together, the vop node is still there but inactive. I've linked a scene so if someone can have a look, that could be nice. Thanks Doum Confettis_falling.hipnc Quote Link to comment Share on other sites More sharing options...
Hudson Posted March 6, 2014 Share Posted March 6, 2014 (edited) Hello, Here is a simple solution that works alright. cheers, Huds Hip-file is now attached. Sorry went away during the weekend and just saw your post. If you dont have figured it out already here is the hip. I even double-checked if the file was attached on last post. But I was mistaken :/ Confettis_falling_oriented.hipnc Edited March 9, 2014 by Hudson Quote Link to comment Share on other sites More sharing options...
Doum Posted March 7, 2014 Author Share Posted March 7, 2014 Thanks Hudson, but I think you forget to attach the hip file ? Quote Link to comment Share on other sites More sharing options...
Hudson Posted March 9, 2014 Share Posted March 9, 2014 I realised my hip, didn't give you a perfect result. Altough you can use it as a start. or it will give you an idea on how to begin Quote Link to comment Share on other sites More sharing options...
Doum Posted March 10, 2014 Author Share Posted March 10, 2014 Thanks again hudson for the help, I took a look at your correction to my hip file and that is a solution that I had already tried, but the problem with this solution is that all particle/confetti have the same orientation when they fall to the ground, that is why I tried to play in Vop pop to change there orientation attribute when they come to a certain distance of the ground, but I wasn't able to blend the orientation from in the air state to the collision state. here I linked an image to explain the problem of alignment. Quote Link to comment Share on other sites More sharing options...
