voronoisplit - piece attrb. problem
Hey there,
I want to use the voronoisplit node to cut my geometry and then i want to group each piece of the resulting geometry.
But i can not acces the "piece" attribute correctly. (it seems to be an integer value)
In the example file i provide you with a setup in which i trie to use the piece atrb for the red color channel to demonstrate the problem.
I hope someone can help me out. This realy makes me headache.
Kind regards
Luk@s
voronoisplit_BUG.hip
@ Novaa:
I still get a complete black cube in your file. It doesnt matter whicht values i feed into the color node or how i set the range or the color (still beeing in the Ramp From Attribute section).
Do you get a different color for each piece?
(i already solved the group problem but i would like to understand your way with the "ramp from atrb." as well ).
Kind regards
Luk@s
