Houdini stuck on import FBX
I am trying to reduce the amount of key frames using maya .
However it gets "stuck" like you mentioned.
There is a key frame on each frame of the 770105 frames. Plus to the end
I think if you re time the sequence somehow it should work,
Cheers
mangi
Hi.
I did a new export to maya with as startframe 1, then shift it in maya with 770105 and reexport it to a fbx.
Now it work!! :) thank for your help
Its still a bit strange that there is no direct export to Houdini in 3dEqualizer and that houdini cant handle to many keyframes with fbx import
