abramov-cg Posted March 24, 2014 Share Posted March 24, 2014 (edited) I have a smoke sim. I want to reduce velocity in the area inside of small box (like in pic). I want to have opportunity to fill this area with custom velocity. Thanks. Edited March 24, 2014 by abramov-cg Quote Link to comment Share on other sites More sharing options...
eetu Posted March 24, 2014 Share Posted March 24, 2014 If you want to just replace the velocity in that area, I think you could just use the pump from the shelf tools, and change the velocity mixing mode to copy. (Source Volume -> Volume Operation -> Velocity -> Copy) Quote Link to comment Share on other sites More sharing options...
gui Posted March 24, 2014 Share Posted March 24, 2014 you can use a mask field to do that... have you tried? Quote Link to comment Share on other sites More sharing options...
abramov-cg Posted March 24, 2014 Author Share Posted March 24, 2014 (edited) Tried different ways to copy vel from my custom fields, tried to multiply this. But nothing works. In attachment scene with pump. If I set to copy - nothing works. Guilherme Casagrandi Ok. I'll try this way Pump_01.hipFetching info... Edited March 25, 2014 by abramov-cg Quote Link to comment Share on other sites More sharing options...
abramov-cg Posted March 25, 2014 Author Share Posted March 25, 2014 (edited) I don't understand how I can use mask field to control global velocity.From help: Quote The mask can be used to modify forces and torques when attached to Force data. And I want to reduce vel in custom area, not for only one force Edited March 25, 2014 by abramov-cg Quote Link to comment Share on other sites More sharing options...
eetu Posted March 25, 2014 Share Posted March 25, 2014 It's weird the pump solution doesn't work, I would've expected it to. Here is a handcrafted version: Pump_01_ee.hipFetching info... 1 Quote Link to comment Share on other sites More sharing options...
abramov-cg Posted March 25, 2014 Author Share Posted March 25, 2014 Thanks man - this is amazing. Its works. It is very strange that we can't do this using gas calculate or gas linear combination. One more problem.. I want to do smooth transition between this velocities, but when we use two way switch we get sharp border. Quote Link to comment Share on other sites More sharing options...
eetu Posted March 25, 2014 Share Posted March 25, 2014 As you can see from the file, I first tried using gas linear combination nodes, but for some reason it didn't quite work so I changed to using a Field VOP. To get a smooth transition, instead of the two way switch, use a Mix VOP, with the "pump" volume value as the mix bias. 1 Quote Link to comment Share on other sites More sharing options...
abramov-cg Posted March 25, 2014 Author Share Posted March 25, 2014 Eetu thanks again. It works exactly as I want Quote Link to comment Share on other sites More sharing options...
eetu Posted March 26, 2014 Share Posted March 26, 2014 On 3/25/2014 at 1:37 PM, eetu said: As you can see from the file, I first tried using gas linear combination nodes, but for some reason it didn't quite work so I changed to using a Field VOP. I just had to revisit this, with a little more attention to detail it works now This one just multiplies down the velocity in the pump area, but extending to an alpha blend should be just a couple of extra gas linear combinations. pump_02_ee.hipFetching info... 4 Quote Link to comment Share on other sites More sharing options...
abramov-cg Posted March 27, 2014 Author Share Posted March 27, 2014 Eetu thanks again. Now it is really simple.. all controls by density. Quote Link to comment Share on other sites More sharing options...
