hrender command on windows machine ...just a puzzle
Please ignore me if it has been discussed previously, I just couldn't find my answer clearly, thanks in advance to help me.
Ok I can run hrender command in a linux machine very easily without doing a lot of fancy things,  normally I make a text file with some few texts in it:
cd /opt/houdini...
source houdini_setup_bash
hrender -v -r -d ...etc
and then open a terminal to say to run this text file as a script
ok now I want to do the same on a windows machine (win7 64 in my case)....really it is a puzzle for me how to do the same,
please guide me
Edited by avak
Something along these line: Start the Command Line Tools from the Start menu, type in csh, now you do: hrender -v -r -d ...etc.
Thanks for the tip,
can you please explain what did you mean of "type in csh"
Ok I opened the Command Line Tool as you mentioned and typed:
csh
then
I typed:
hrender
the consol answers:
cat: command not found.
rm: command not found.
what did I wrong here?
Thanks,
Edited by avak
Ah right, hrender uses additional tools normally found on Linux. You might need Cygwin, or better yet use hython. eg. forums.odforce.net/topic/16383-verbose-in-hython-render-command/
 ok let me check the link and will comeback here again
  • 4 weeks later...
I don't know if you managed it or not,
any way let me answer you in its simplest way which it is :
suppose you have a scene on drive D named "shot.hip" and its path is "D:/shot.hip"
and we have a mantra node named "mantra1" and its path is "/out/mantra1" in your scene.
ok
press win button on keyboard type : command line tool and press enter
it opens a command shell
type: hscript d:/shot.hip and press enter . then type:
render -v /out/mantra1
that's it
I admit you're right that using hrender command in windows  is not as easy as in linux  . any way by using hscript command you have more option to tweak and can do more .
suppose you have a dop output node in your scene "/out/dop" and by using hscript with the same fashion as explained above you can run simulation without opening houdini and save a lot of ram for simulation this way.
  • Like 2
  • Thanks 1
