slamfunk Posted March 27, 2014 Share Posted March 27, 2014 Hey guys, are .rat files mip-mapped when created with iconvert or do you need to add a special tag? the help for iconvert mentions a mipmaps tag but I don't know where to put it or if I even have to... any thoughts? Quote Link to comment Share on other sites More sharing options...
teratera Posted March 27, 2014 Share Posted March 27, 2014 Hi Vasilis, I'm sorry for stepping in, but I'd like to use the opportunity to ask those knowledgeable who'll be here. Is there any good read about using mip-maps in Houdini you could recommend? I think I understand the idea, and I believe .rat does the magic automatically, but how do you use it with production needs? So for example, I have a geometry with one UV set and I have a camera which eventually zooms into certain area on this geometry. And so I obviously need higher resolution in this area and keep rest low-res. What is the proper way to prepare a texture for such a situation? Do I have to do a single high-res file and convert to rat (that would be resizing base low-res texture to fit hi-res and then merge hi-res piece over it)? Or is there other more suitable ways? 1 Quote Link to comment Share on other sites More sharing options...
symek Posted March 27, 2014 Share Posted March 27, 2014 Rats files are mip-mapped by default, no need to add any tag nor do anything else but saving your texture as *.rat. @teratera: I also haven't meet any limitations. Make texture enough big to handle your close up, then convert it to rat file. Rats are not only mip-mapped but also tiled. It can easily handle >48K resolution. 2 Quote Link to comment Share on other sites More sharing options...
teratera Posted March 28, 2014 Share Posted March 28, 2014 Thanks a lot for clarifying, symek. Quote Link to comment Share on other sites More sharing options...
slamfunk Posted March 28, 2014 Author Share Posted March 28, 2014 Thanks for the response symek and thanks for asking my next question teratera! Quote Link to comment Share on other sites More sharing options...
