Cartoon Style
khalid
Hello
I try to do a cartoon and i found this video :
A nice effect , but im still a begnner with Houdini , if someone can make a setup to help me understund how the owner of this video did that.
Thanks
I think used the two tone material and another pass for outlines rendered through "wren" node instead of mantra
hmm ... a houdini's file will help me to understund :) , sorry but im still beginner and i dont know the all nodes ans operators in houdini.
THanks
Niice :) thanks Anim !!
you can search the forums for toon shading to learn more how it can be done in Houdini
or this tutorial may be useful
https://cmivfx.com/store/571-houdini+cartoon+effect
as it has references directly to Junichi Akimoto, the author of the video you posted
Hi
i Dont have the tutorial :( and i looked for idea in forums and not found it , im looking specially for the motion blur look in cartoon style
Jeff have made a post with a toon shader example (very simple). maybe that can help you a bit.
in this tutorial from ari denish he used in the last example the wren render in combination with the compositing nodes:
http://www.sidefx.com/index.php?option=com_content&task=view&id=2216&Itemid=361
i think the cmivfx video should be pretty good but if you can't get it the only way would be to learn more on vex shadeing and compositing.
just for information in the new blender release there is a toon render build in. but also there you have to learn the concept.
or just search for a tutorial for another software and analyse the concept and adapt it to houdini. (it's the hard way)
thanks for informations MANDRAKe :) . i will see the video , but in the same time want to know how he select some points from the mesh and make trailes to make a motion blur style cartoon like he did in the video
well my knowledge is very limited with vex so i can't give you a finished solution that works... but the rough way is shown in the video how it's done.
1. paint for selection of the area (maybe custom group)
2. scatter for creating points
3. some vop sop here
4. emit particle from the area where you selected.
5. create lines
6. create a custom shader
something like that will it be. look at the video tutorials from ari danesh
maybe this one helps: http://www.sidefx.com/index.php?option=com_content&task=view&id=2635&Itemid=389
5. create lines
Yes , Thanks a lot , this is the same thing that i understund from his video , i dont reaaly know what he did for the VOP SOP but i will look for that, thansk for the link. i will answer you when i'll have some things cool :)
Thanks
  • 1 month later...
