Deforming packed geometry doesn't work in DOPS
XJIOR_UA
Thank you for your answer. I need to use packed objects, because i will be use a lot of them. They are very faster then ordinary bullet primitives. If i unpack them in SOP solver, RBD packed object node throws error about attribute NAME, because it use only 1_point object. Maybe exist another way to scale particles in this network?
