Hello world Posted April 10, 2014 Share Posted April 10, 2014 I have a float attribute called temp in attribcreate and i use paint sop to visualize this attribute and paint it.. now how the values are manipulated for eg: now on point 22,the color has rgb of (1,0.3,0) but the float attribute which i have overridden color in paint sop has a value of 0.9.. how this conversion happens Quote Link to comment Share on other sites More sharing options...
DASD Posted April 23, 2014 Share Posted April 23, 2014 It is rather dificult to understand your exact problem. Maybe you could upload your file to make things a bit clearer. Quote Link to comment Share on other sites More sharing options...
anim Posted April 23, 2014 Share Posted April 23, 2014 that's because if you are using float attrib instead of Cd Paint SOP visualizes it's value in one of the modes of Visualize Mode parameter (which is by default Infra-Red) so that's where the remapping comes from on top of that you can adjust Visualize Attribute Range to remap your attribute value from to get exact representation of your float value intensity as color choose Grayscale Visualize Mode and don't use any remapping range but usually you don't need Cd to be the same, that's why you are painting different attribute than Cd Quote Link to comment Share on other sites More sharing options...
