Is it possible to built a flip tank cluster.
I want to built a big scale flip tank in H13.
I can manual set the scale or transform animation.
But is it possible set a flip cluster have two or more flat tanks include, so i can put them along a curve.
I have try to merge them together, out of work.
Some tips will be great.
Thanks.
I'm not sure what your trying to simulate but if you have an object that is moving through a tank and it needs to span a large area, you may want to try the Flat Tank setup form the shelf, its a pretty cool feature in H13 http://vimeo.com/89039534a
Actually i want built a flip simulate with two or more flat tank include,  such as pyro cluster.
So i can retain the foam trail  along a long curve.
