tomwyn Posted May 6, 2014 Share Posted May 6, 2014 Hi all, This might seem weird, but for some reason when I use the bbox function & try to return the YSIZE, YMIN or YMAX, I get the X values... Is this an issue others have had? Or am I missing something incredibly obvious in my global scene setup or something? I've attached a simple example here where I'm trying to call the YSIZE of a tube. (Full disclosure, I'm attempting to implement a noise controlled by a ramp, as can be found in examples kindly shared by Skybar & VBK on this thread http://forums.odforce.net/topic/18610-from-sop-nodes-into-a-single-vop-a-learning-process/ ) YSIZE_issue.hip Quote Link to comment Share on other sites More sharing options...
Skybar Posted May 6, 2014 Share Posted May 6, 2014 In your VOPSOP, you are taking the wrong float from the VecToFloat. In order, they are XYZ for components 123 respectively. So since you want Y, you should take component 2 (the middle one). Right now you are taking the first, which is X and that is why you are getting X's values. Why it kinda works okay though is because your box is a perfect cube, so the YSIZE is the same as XSIZE. Quote Link to comment Share on other sites More sharing options...
tomwyn Posted May 6, 2014 Author Share Posted May 6, 2014 Thanks Skybar, I knew it would be something silly that I'd missed! Appreciate the reply! Quote Link to comment Share on other sites More sharing options...
