amin.khormaei Posted May 14, 2014 Share Posted May 14, 2014 i wonder when you write this expression ("../something" , something else) in a section what do you tell houdini to do? please help me? i don't know what users call this , if i have knew this i have referred to houdini help. if someone could help me with more detail i'll appreciate you, best regards... Quote Link to comment Share on other sites More sharing options...
amin.khormaei Posted May 14, 2014 Author Share Posted May 14, 2014 hello? Quote Link to comment Share on other sites More sharing options...
jkunz07 Posted May 14, 2014 Share Posted May 14, 2014 hard to tell from your question as: ("../something" , something else) is just two arguments. One example might be: centroid("../null1", D_X) in which case your getting the x component of the centroid of the geometry in "../null1" This is commonly used in an add sop to fill in each component of the created point's position like: centroid("../null1", D_X) centroid("../null1", D_Y) centroid("../null1", D_Z) So you will have a point which represents the centroid of whatever geometry is fed into "../null" Maybe look at the sidefx expression docs or use exhelp in the textport for more info Quote Link to comment Share on other sites More sharing options...
