Undertaker Posted July 15, 2004 Share Posted July 15, 2004 Hi everybody, I am using a ASAD light shader on a sphere in order to use this sphere's point as cone lights, but I wonder how I can assign a color ramp to this ASAD light shader. For example I would like to have the top point to be blue and the bottom point to be red, basically asigning a Color on the Y axis. Do I have to use an image map, even though that is not very flexible ? or maybe an expression in an attrib Create Sop ? Thanks in advance Julien Quote Link to comment Share on other sites More sharing options...
stevenong Posted July 15, 2004 Share Posted July 15, 2004 Hey Julien, Assign a Point SOP to the Sphere & turn on "Add Color". Use the following in the fields: R = 1-$BBY G = 0 B = $BBY which should make the bottom half of the sphere red & the top blue. If this doesn't work for you, you can always use a Paint SOP. Finally, in the AttribCreate SOP, replace the colour values with $CR $CG $CB Cheers! steven Quote Link to comment Share on other sites More sharing options...
Undertaker Posted July 16, 2004 Author Share Posted July 16, 2004 thanks ! Quote Link to comment Share on other sites More sharing options...
