dark polygons problem with FBX import
Juraj
I have strange problem with some polygons.
When I import FBX model sculpted in Mudbox, I get theese dark polygons in rendered image.
However it looks fine in viewport.
I have tried different FBX import options, or SOPs like clean, fuse, facet... Nothing helped.
Normals are looking fine.
Any ideas how to fix it?
Thanks
post-11577-0-40399000-1400440236_thumb.j
post-11577-0-20404700-1400440237_thumb.j
they should be self-shadows and are apparent as you most likely have low polys and smooth normals - they can be removed by:
increase your bias in Mantra/Properties/Shading
or
Check Render Polygons As Subdivision (Mantra) on your geometry node/ Render tab
or
check Backface Removal on your geometry node / Render /Geometry tab
Find out more:
http://odforce.net/wiki/doku.php?id=raybias&s[]=bias
http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=31385
Thank you, your solutions fixed it.
I'd never figure it out by myself.
I also tried to import it into Maya and render with Maxwell and Mental Ray. Interesting that Mental rendered it fine by default.
post-11577-0-27604000-1400442253_thumb.j
Edited by seals77
the artefact is created by the shadow. the shadow is created by at shader/render time so it has to be dealt with then.
Edit: woudl it be possible to post a screen shot of the mental ray with shadows, thanks! It would be good to see it to compare.
Edited by tar
