skip_odforce Posted May 24, 2014 Share Posted May 24, 2014 (edited) hi guys I met a very strange problem. When I render region in vire port, the ocean waves looks fine, but I got the wired result when I render mantra. Does anyone meet the problem? Edited May 24, 2014 by skip_odforce Quote Link to comment Share on other sites More sharing options...
Guest tar Posted May 24, 2014 Share Posted May 24, 2014 Is your render using ray-tracing? Quote Link to comment Share on other sites More sharing options...
skip_odforce Posted May 24, 2014 Author Share Posted May 24, 2014 (edited) No, I use physically based rendering I found there was something to do with the camera. I exported the camera from MAYA via FBX, and scaled it from 1 to 0.01 The image looked like the ocean surface had been cut top part. I created a new camera from houdini and snapped it to the camera from Maya and rendered. It works. I wonder if there is a correct work flow of exporting camera from Maya to Houdini and make sure the ocean waves will also be rendered correctly? Edited May 24, 2014 by skip_odforce Quote Link to comment Share on other sites More sharing options...
mawi Posted May 24, 2014 Share Posted May 24, 2014 Big NO NO. Dont scale cameras! Quote Link to comment Share on other sites More sharing options...
merlino Posted May 24, 2014 Share Posted May 24, 2014 Try using Alembic and not FBX. Probably you'll end up with less problems. Quote Link to comment Share on other sites More sharing options...
Guest tar Posted May 25, 2014 Share Posted May 25, 2014 see if tamte post helps with camera scale: http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&p=142496&highlight=#142496 Quote Link to comment Share on other sites More sharing options...
skip_odforce Posted May 25, 2014 Author Share Posted May 25, 2014 (edited) Thank you marty and merlno, I will try. By the way, I wonder how you render the passes(or AOVs) of the ocean waves. Especially the diffuse, reflection, refraction,velocity and vorticity. Is there any tutorial? Edited May 25, 2014 by skip_odforce Quote Link to comment Share on other sites More sharing options...
biswajitfx Posted September 3, 2015 Share Posted September 3, 2015 its a camera scaling issue. u have to scale the camera(scenes)from maya while exporting abc. Quote Link to comment Share on other sites More sharing options...
fathom Posted September 3, 2015 Share Posted September 3, 2015 you can also insert a scale to return to unity and all will be good. Quote Link to comment Share on other sites More sharing options...
