Closest Location with VDB
Thanks edward for the reply,
That the way I think I have to go, but I have no clue which node to use inside vop, I have checked the openvdb exemple file and saw the use of the closest location there.
Do I have to compute the closest point for the 2 geometry?
What I got for the moment is a vdb from poly for the sphere and the box + closest point for the 2 and merge them together plugged in a volume vop.
how do you add or apply the deformation to the level set since it a scalar and the closest point is a vector ?
I'm a bit lost with vdb, if one of you have some more examples to share with vdb and volume vop I'll be interested to see them.
Thanks
Doum
  • 4 months later...
