project mapping on to instanced objects
muzaffer
Hi All,
I have a issue doing mapping image from project cam to instanced objects, using instance sop not "copy sop"
probably there is a easy solution I am skipping.
if my question is not clear enough  i can throw a hip file here.
Any pointers would be greatly appreciated.
cheers
  • 2 weeks later...
In the shader of object to be instanced you need to transform P into camera space.
In VOPs:
The "lightndc" option of the transform VOP seems to do this. The docs say it's intended for a light shader but in the surface context, it seems to read the global render camera. I suppose you could use lights in the scene to effectively project from alternate angles as well.
Wire P into transform VOP set from current to lightndc.
Split the vector and use U and V as the S and T input to your texture operation.
