Alexey Vanzhula Posted June 19, 2014 Share Posted June 19, 2014 what is differences between sop setCurrent and setSelected methods ? Quote Link to comment Share on other sites More sharing options...
edward Posted June 19, 2014 Share Posted June 19, 2014 By definition, the "current" node is the last selected node. When you have unpinned panes, the path for the pane (eg. Parameter pane) will switch to the the last selected node. In the parameter pane for example, the "current" node is the one that is displayed in front amongst all the selected nodes. So I think setting a selected node as current should re-order the selection nodes so that it becomes the last selected node. (mind you, I haven't tested any of this ) Quote Link to comment Share on other sites More sharing options...
Alexey Vanzhula Posted June 19, 2014 Author Share Posted June 19, 2014 thanx Quote Link to comment Share on other sites More sharing options...
