volumevop | indexing a component of vector field
Why directly indexing into a given component of a vector field using parm type float doesn't work ?
For example volume prim having a named attribute "test.x"  isn't accessible with the same name of type float inside volume vop.
Some insights will be helpful :)
Thanks,
-Gaurav
From the help:
  Quote
Autobind by Name
Will use the name primitive attribute to determine which volume binds with which parameter. If the name attribute isn’t present, the first volume is bound to density.
A name like “foo” will be bound to the float parameter “foo”. A name of “foo.x” will be bound to the x component of the vector (three float) parameter “foo”. A name like “foo.zx” will be bound to the x,z component of the matrix (three by three) parameter “foo”.
Since it's a vector component it is bound as the X of that vector, despite it being a float field on its own. So simply access the vector field as "test" and then Vector To Float VOP or Get Vector Component VOP to access X.
Hi David,
My question is why direct indexing doesn't work ?
AFAIK vector data type in single houdini volume primitive is n't possible yet. since vector fields are 3 separate volume primitives stacked up togather.
What prevents volumevop accessing each primitive directly.
Thanks,
-Gaurav
I misunderstood you question, thought you are talking about accessing vector volume component directly by name with volumesample() as opposed to getting the whole vector volume using volumesamplev(), which works
but back to you original question
you can't name vex variable therefore parm using . (dot) , it will get converted to _ (underscore) so your variable would bind to volume named test_x if it would exist, not test.x
in wrangle it's much more straightforward v@test[0]
but I don't think that creating vector parm/bind vop and extracting component you want is a bad thing, it makes your code work independently of whether you use merged VDB vector volumes or split ones
and it's consistent with attributes
Edited by anim
