MorhafMehena Posted July 16, 2014 Share Posted July 16, 2014 okay guys, this is driving me crazy. I have a bgeo flip sim cached out (with surface and velxyz fields), then somehow deleted my source file. So I now want to add whitewater to my cached sim. How do I set this up? I'm bringing the sim in with a file node, then I just click the shelf tool. it tells me to select a fluid, so I select my file node (what else is there) and I get an error saying no fluid selected.. What am I supposed to do? Quote Link to comment Share on other sites More sharing options...
Skybar Posted July 17, 2014 Share Posted July 17, 2014 The easy way is to create a new setup from the shelf, flip and everything. Add whitewater to that. And then just re-link stuff to use your cached flip and delete what you dont need again. Quote Link to comment Share on other sites More sharing options...
Hiro_FX Posted July 17, 2014 Share Posted July 17, 2014 You have to 'load from disk' the bgeo cache in the DOP I/O node you used to export it (if you used a ROP, it's the one you connected with) and then it will work using the shelf tool and selecting the fluid. It will simulate the whitewater from the cache file. Quote Link to comment Share on other sites More sharing options...
Guest frostbite Posted July 21, 2014 Share Posted July 21, 2014 Just put a "file" and a "switch" node so that your white water network points to the file node (cached bgoes) as a source. Quote Link to comment Share on other sites More sharing options...
