Sequentially Carve Lines
on the "attribvop_carveVal" vop there's a Maximum time parameter which if you decrease will speed up the growth of the lines.
It's not the most controlled way (no specific value to determine the gap between) but if you increase the value of the "addconst1" inside the "attribvop_carveVal" it will create a blend between the growth.
