Rotate from (0,1,0) to (0,-1,0) with dihedral
There is dihedral vex and hscriptExpression functions to calculate rotations.
How to rotate for example from (0,-1,0) to (0,1,0), when angle between vectors is 180°.
I can parse vangle hscriptExpression function result with if statement, but what is correct decision ?
Edited by Alexey Vanzhula
dihedral will compute rotation from {0,-1,0} to {0,1,0} with no problems
the only catch is that there is infinite number of possible rotations between opposite vectors as there is no rotation axis strictly defined as in the case when those vectors are not parallel
so you need to define perpendicular axis to these vectors to rotate about if you really care about exact rotation
so once you have your perpendicular axis you can just use
rotaxis() expression function
or
quaternion(angleaxis) or quaternion(angle, axis) or rotate() VEX functions
to get your desired rotation
