how to keep creation frame in attribute
murathan altunsoy
i would reverse your logic.  don't delete random points and then try to figure out when they were no longer deleted.  instead, generate your birth time and then delete the points with a birth time that is greater than the current time.
Edited by fathom
thank you your file wateryfield. i try  that its good but when i use random create point its not working.
 i use random delete because i want use that for all things.especially lsystem.if i try on lystem its not working.there fore i use random delete.miles
create_time_2.hipnc
Edited by murathan747
