acc3d Posted August 19, 2014 Share Posted August 19, 2014 Does anybody know if a DOP Network automatically generate sub-integer frames if you set sub steps higher than 1? For example, if I pass in some geometry from SOPs that's saved on disk in integer frames, does DOPs automatically interpolate subframes, of would I need to use a Timeblend to generate subframes. Quote Link to comment Share on other sites More sharing options...
Skybar Posted August 20, 2014 Share Posted August 20, 2014 No, it won't do that for you. If you have integer geo, and you want interpolated subframes, you have to use the Timeblend SOP. Quote Link to comment Share on other sites More sharing options...
acc3d Posted August 21, 2014 Author Share Posted August 21, 2014 Great, thanks for confirming my assumption! Quote Link to comment Share on other sites More sharing options...
old school Posted August 21, 2014 Share Posted August 21, 2014 The Wire and Cloth/Solid solvers can do swept collisions of surface colliders as these solvers will sub-step between global sub-steps. Drag the geometry through the sub-steps linearly. All other solvers (pyro, flip), you have to make sure the geometry moves correctly at sub-frame intervals. Quote Link to comment Share on other sites More sharing options...
