Follyx Posted September 1, 2014 Share Posted September 1, 2014 Hi, is there a way to cook - not to render - on multiple machines wihout splitting the file? Quote Link to comment Share on other sites More sharing options...
edward Posted September 1, 2014 Share Posted September 1, 2014 Yes, but you need to manually decide how you want to split the cooking amongst the machines and which node to cook on each machine. It depends on what type of cooking you want. For geometry, the easiest way is to use Geometry ROPs to cook your nodes, outputting the intermediate results to independent files. Then you can combine the results via File SOPs. The NetBarrier ROP can also help in synchronizing between the different machines. 1 Quote Link to comment Share on other sites More sharing options...
Follyx Posted September 1, 2014 Author Share Posted September 1, 2014 i'll give it a try. thanks in advance Quote Link to comment Share on other sites More sharing options...
