Tornado sim not spinning around particles correctly!
Tyfx567
I have been at this project for a while now and am so sick of this not working. I just can't seem to make the tornado spin around the right way and be more directed by the particle movement. Can someone tweak this and give it back or merely give some suggestions based on the file? That would be awesome!
Description:
Particles emitting from circle based on surfaces.
Volume from Tube for velocity input.
Made normals controller to direct toward center of tunnel and down.
Emitting fluid from particles using pyro solver from the billowy smoke shelf tool.
Thanks so much!!
Tornado with fluid_fuel try3.hipFetching info...
